15 years agoProgramming EP3C5E144C8N
I'm looking for informations to confirm me the last step of my work. I would like to programm an EP3C5E144C8N with an EPCS16SI8N from a BYTEBLASTER. I've followed datasheet from CIII_HandBook and EPCS datasheet to make a correct schematic, but I have a doubt about ths MSELs pins, so can someone help me please. I selected the Fast Active Serial Fast (with the appropriate schematic) and put MSEL as follow : MSEL[0] = '1' / MSEL[1] = '0' / MSEL[2] = '1' and this FPGA has no MSEL[3] for having a logic one on the previous MSEL, I connect them to VCCA (2,5V) via a 0ohm resistance but the related bank (#6) has a VCCIO at 3,3V. So I'm confuse with that :confused: Someone recommend me to use the Fast Active Serial Standard but couldn't tell me exactly why and how to change my schematic in that way can someone help me please if more information are needed don't hesitate thanks in advance1 Reply
after many reading of AN and other datasheet
I'll do that : all my banks concerning configuration are at 3.3V ep3c5e144c8n hasn't got a third MSEL so Fast POR is eliminated so i'll connect the MSEL as following MSEL[2]='0' / MSEL[1]='1' / MSEL[0]='0' '0' = GND and '1'=Vcca so 2.5V in addition to that, i'll add a 25Ohm resistor near EPCS in the connection between DATA(EPCS) and DATA0(FPGA) and then i'll hope it will work if someone can confirm me that, i'll kindly appreciate thanks in advance
