17 years agoPrograming CFI Flash
Hello, I want to run a NIOs processor on a Cyclone III with code stored in a CFI flash. The FPGA is programed via an EPCS controller. How do i program the code on to the CFI flash? Do i ne...
16 years ago --- Quote Start --- Thanks for all of your help. I am actually going to use Active Parallel programing and store the FPGA configuration and the nios code on the same flash. I assume i program the flash the same using the flash-programmer? Thank You Matt --- Quote End --- ---------------------------------------------------------------------------------------------- Hi Matt, How do I program FPGA configuration and nios code on the same CPI flash?If do so,epcs flash memory still needed? Any guidance for me?Thanks.
