16 years agoProgram device seems no response in signaltap after changing source code
Initially, I could program .sof file & run signaltap without any problem. I tried to alter the source codes like adding a new signal & output port. After that, I recompiled my design. Then, I opened ...
16 years agoHi FvM,
Thanks again for your quick response....... What I've observed is that the .sof file is programmed successfully. But I cannot run acquire data due to error "program device to continue"... One thing i forgot to mention is regarding the Logic element (LE)......90% LE is consumed in my design....Will this cause the error "program device to continue" in my signaltap II? Thanks regards, Dave
