16 years agoProgram device seems no response in signaltap after changing source code
Initially, I could program .sof file & run signaltap without any problem. I tried to alter the source codes like adding a new signal & output port. After that, I recompiled my design. Then, I opened ...
16 years agoYou may want to check otherwise, if the FPGA (still) holds the intended configuration image, e.g. by setting a hardware pin, toggling a LED, whatsoever. In most cases, the configuration has been deleted, e.g. because your hardware triggered NCONFIG.
