16 years agoProgram device seems no response in signaltap after changing source code
Initially, I could program .sof file & run signaltap without any problem. I tried to alter the source codes like adding a new signal & output port. After that, I recompiled my design. Then, I opened ...
16 years agoHi FVM,
Thank you for your suggestion..... The .sof file programmed into FPGA is selected from correct directory. Also,they halt on-chip configuration controller is never enabled by Quartus programmer. I also tried to enable it but I got the similar error "Program Device to continue".. Is there any other possibility reason on getting this error? Your help or anyone help would be greatly appreciated....Many thanks....
