16 years agoProgram device seems no response in signaltap after changing source code
Initially, I could program .sof file & run signaltap without any problem. I tried to alter the source codes like adding a new signal & output port. After that, I recompiled my design. Then, I opened ...
16 years agoA common mistake is to download a different *.sof file or a same-name file from a different directory. Another possibility is, that your hardware causes a configuration request and deletes the JTAG-loaded configuration. This can e.g. happen, if a connected AS configuration device doesn't contain a valid configuration. The on-chip configuration controller should be disabled by a Quartus programmer option in this case.
