17 years agoProcess Wait Statement
Please help me!!! I use Process Statement for my project, but have error: In Process Statement, we just have only one Wait untill??? It is wrong or right??? please help me. Thanhks a lot. pro...
12 years agoThe code provided by lizhi0007 should be synthesizable according to IEEE Standard 1076.6 - Standard for VHDL Register Transfer Level (RTL) Synthesis.
There are many rules that must be abided to for a wait statement to be synthesizable. However, it is incorrect to simply state that such statements are not synthesizable. The most notable rule is that all the wait statements in a process (yes, there can be more than one) must specify the same edge of a single clock for the process to be synthesizable. This technique is used to specify "implict finite state machines". Here is an example, extracted from IEEE 1076.6, of a process with multiple wait statements that should be synthesizable:library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
Entity Mult is
port(
clk : in std_logic;
start : in std_logic;
done : out std_logic;
A, B : in unsigned(3 downto 0);
Y : out unsigned(7 downto 0)
end Mult;
Architecture ImplicitFSM of Mult is
signal intY : unsigned(7 downto 0);
begin
MultProc : process
begin
wait until clk = '1';
if start = '1' then
done <= '0';
intY <= (others => '0');
for i in A'range loop
if A(i) = '1' then
intY <= (intY(6 downto 0) & '0') + B;
else
intY <= (intY(6 downto 0) & '0');
end if;
end loop;
done <= '1';
end if;
end process;
Y <= intY; -- final state Y = A * B
end;
I wonder when Quartus will support that?
