14 years agoProblems with verilog state machine
Hi.
My state machine seems to get stuck in one of the states, but if you remove px_gate it begins to work properly. I can not understand this strange behavior. Code:
module sync2de(clk,hs,vs,px_in,de,px_out);
input clk;
input hs;
input vs;
input px_in;
output px_out;
output de;
wire px_gate;
reg state=0;
reg counter;
assign px_out=clk && px_gate;
always@(state)
begin
case(state)
0: begin
px_gate=1;
de=1;
end
1: begin
de=0; px_gate=1;
end
2: begin
de=0; px_gate=1;
end
3: begin
de=0; px_gate=0;
end
4: begin
de=0; px_gate=0;
end
endcase
end
always@(negedge clk)
begin
case(state)
0: //wait sync
begin
if(!vs)
begin
counter=v_blank_lines-1;
state=1;
end
else
if(!hs)
begin
counter=h_blank_px-1;
state=2;
end
end
1: // vs
begin
if(counter)
begin
state=3;
end
else counter=counter-1;
end
2: //hs
begin
if(counter)
begin
state=4;
end
end
3: //vs_end
begin
if(vs)
begin
state=0;
end
end
4: //hs_end
begin
if(hs)
begin
state=0;
end
end
endcase
end
endmodule
Thanks.2 Replies
Yes, it was asynchronous inputs. Thanks.
Apart from the design being incomplete (missing constants) I don's see a particular problem related to px_gate, because it's not affecting the state machine operation.
As a more general comment, if the hs and vs input signals are not synchronous to clk or don't keep the setup and hold times related to clk, there's a good chance for the state machine to get stuck at an illegal state. hs and vs need to be synchronized to clk in this case. There's also a risk, that the state machine doesn't reset properly, depending on the initial behaviour of clk and input signals. A synchronously released reset according to the suggestions in the Quartus software handbook avoids this problem. P.S.: As every gated clock, the output clock can be expected to have glitches. This isn't a problem for the present design, but for succeeding logic.
