14 years agoProblems with verilog state machine
Hi. My state machine seems to get stuck in one of the states, but if you remove px_gate it begins to work properly. I can not understand this strange behavior. Code:
module sync2de(clk,hs,v...
14 years agoApart from the design being incomplete (missing constants) I don's see a particular problem related to px_gate, because it's not affecting the state machine operation.
As a more general comment, if the hs and vs input signals are not synchronous to clk or don't keep the setup and hold times related to clk, there's a good chance for the state machine to get stuck at an illegal state. hs and vs need to be synchronized to clk in this case. There's also a risk, that the state machine doesn't reset properly, depending on the initial behaviour of clk and input signals. A synchronously released reset according to the suggestions in the Quartus software handbook avoids this problem. P.S.: As every gated clock, the output clock can be expected to have glitches. This isn't a problem for the present design, but for succeeding logic.
