10 years agoProblems with NANO/ATLAS SOCKIT
in this example controlling LEDS throught AXI from C code,
the project in QUARTUS II in top level ghrd.v shows this "connection" (from qsys export) as: soc_system u0 ( .pio_led_external_connection_export(LED), and LED bus deffinition on MODULE at ghrd.v, (assigned to LED pins in PIN PLANNER) output [7:0] LED, then if i create this BUS: output [7:0] DATA1, and change the line in SOC_SYSTEM: soc_system u0 ( .pio_led_external_connection_export(DATA1), Compiler shows like PIN LED[x] is stuck at GND, dowsnt work (BDF schematic file does not affect in the project). If i put DBF as TOP LEVEL in hierarchy and create a symbol for ghrd.v, then connecting to pins out (like an "Interface" of the original example) like: http://i.imgur.com/3uiczoc.jpg y get errors Error: The auto-constraining script was not able to detect any instance for core < hps_sdram_p0 > and doesn't work. How can i use a DBF schematic in a project with SYSTEM_SOC module as shows my_first_hps-fpga example?No RepliesBe the first to reply
