MartBent
3 years agoProblems using a Dual access on-chip memory module (QSYS)
I have a QSYS system using a Nios II/e processor along with some vhdl modules which should be able to display pixels on a LCD display using a VGA controller. I have already managed to get t...
- 3 years ago
So I finally solved the issue...
The problem was that the frame_buffer address immediately changed back after 1 clock cycle. Since the memory has a delay it needs to be kept at their desired value for at least 2 clocks cycles, doing this will result in the readdata value changing in the third clock cycle. I have another post on reddit with a bit more context:
https://www.reddit.com/r/FPGA/comments/y1fkb1/problem_accessing_sdram_from_nios_iie_and_vhdl/
sstrell
3 years agoHosts use byte addressing, so you should be increasing your address by 4 each time for a 32 bit data bus, but that doesn't explain the lack of change on readdata. Hmm.
