MartBent
3 years agoProblems using a Dual access on-chip memory module (QSYS)
I have a QSYS system using a Nios II/e processor along with some vhdl modules which should be able to display pixels on a LCD display using a VGA controller. I have already managed to get t...
- 3 years ago
So I finally solved the issue...
The problem was that the frame_buffer address immediately changed back after 1 clock cycle. Since the memory has a delay it needs to be kept at their desired value for at least 2 clocks cycles, doing this will result in the readdata value changing in the third clock cycle. I have another post on reddit with a bit more context:
https://www.reddit.com/r/FPGA/comments/y1fkb1/problem_accessing_sdram_from_nios_iie_and_vhdl/
uk49s
3 years agoRead this discussion. May be this can help you here https://community.intel.com/t5/Intel-Quartus-Prime-Software/On-Chip-uk49s-Memory-in-Qsys-Quartus/td-p/126471. If yes then please mentioned me here.
