15 years ago
problem with VHDL
I have been involved in some programming project but suddenly a problem started coming.
in the timing.vhd file from line 114 to 147 i have defined two signals sSTOP and sStop_1 as well as sTEMP. when I simulate these files with timing as a top level entity, the vector waveform file always show a negative sSTOP signal, not only this the initial value of sTEMP is "001" but it takes some random value.
is there a bug in the software?
if not when i try to burn the same project on cyclone III it never shows me the output
kindly help me in this and please rectify if there are some mistakes .
thanq
    looking at your code, once sStop goes to '0', it stays there until async reset is asserted. Did you mean it to work like this?
    sorry there was some error now i have uploaded again
    plz try this one
    begin
    ACC1 :acc port map (
    inp => sCHANNEL(to_integer(sTEMP)),
    rst => sRST,
    clk => sCLK,
    imp => sComp,
    op => sOP
    counter1 : counter port map (
    rst => sRST,
    trigger => sTRIG_in,
    clk => sCLK,
    digit => sDIGIT
    compare1 : compare port map (
    clk => sCLK,
    rst => sRST,
    inp1 => sOP,
    inp2 => sDIGIT,
    output => sComp
    proc1 : proc port map (
    inp_pulse => sComp,
    clk => sCLK,
    rst => sRST,
    op => sOutput
    sSIGNAL <= (others => '0');
    process(rst,clk)
    begin
    if (rst = '1') then
    sTEMP <= "001";
    sStop_1 <= '1';
    -- sOP <= (others => '1');
    elsif (clk'event and clk = '1' and sCOMP = '1') then
    sTEMP <= sTEMP + "001";
    if (sTEMP = "100") then
    sStop_1 <= '0';
    end if;
    end if;
    end process;
    Process (rst, clk)
    begin
    if (rst = '1') then
    sSTOP <= '1';
    elsif (clk' event and clk = '1') then
    if (sCHANNEL(to_integer(sTEMP))=X"00000") then
    sSTOP <= '0';
    end if;
    end if;
    end process;
    --sample1 <= sStop_1;
    --sample <= sSTOP;
    sRST <= rst;
    sCLK <= clk;
    sTrig_in <= trig_in;
    sCHANNEL <= CHANNEL;
    output <= sSTOP and sOutput and sStop_1;
    end behavior;
    Your zip file seems to be corrupted. Just embed your code in your message between code tags.
