15 years agoproblem with VHDL
I have been involved in some programming project but suddenly a problem started coming. in the timing.vhd file from line 114 to 147 i have defined two signals sSTOP and sStop_1 as well as sTEMP...
15 years agosorry there was some error now i have uploaded again
plz try this one begin ACC1 :acc port map ( inp => sCHANNEL(to_integer(sTEMP)), rst => sRST, clk => sCLK, imp => sComp, op => sOP ); counter1 : counter port map ( rst => sRST, trigger => sTRIG_in, clk => sCLK, digit => sDIGIT ); compare1 : compare port map ( clk => sCLK, rst => sRST, inp1 => sOP, inp2 => sDIGIT, output => sComp ); proc1 : proc port map ( inp_pulse => sComp, clk => sCLK, rst => sRST, op => sOutput ); sSIGNAL <= (others => '0'); process(rst,clk) begin if (rst = '1') then sTEMP <= "001"; sStop_1 <= '1'; -- sOP <= (others => '1'); elsif (clk'event and clk = '1' and sCOMP = '1') then sTEMP <= sTEMP + "001"; if (sTEMP = "100") then sStop_1 <= '0'; end if; end if; end process; Process (rst, clk) begin if (rst = '1') then sSTOP <= '1'; elsif (clk' event and clk = '1') then if (sCHANNEL(to_integer(sTEMP))=X"00000") then sSTOP <= '0'; end if; end if; end process; --sample1 <= sStop_1; --sample <= sSTOP; sRST <= rst; sCLK <= clk; sTrig_in <= trig_in; sCHANNEL <= CHANNEL; output <= sSTOP and sOutput and sStop_1; end behavior;
