16 years agoProblem with verilog
First of all excuse my english (french guy)
Well i want to do something simple with quartus but it doesn't work! the idea is the following one: i have a counter "count", 2 clocks "CLK1" and "CLK2" and a button "Bu" when Bu=0 count=count+1 at each posedge of a clock "CLK1" when Bu=1 count=count+1 but on posedge of another clock CLK2 more rapid than CLK1 when Bu returns to 0, count increases at the rythme of CLK1 CLK1 pos pos pos CLK2 pos pos pos pos pos pos pos pos pos pos pos Bu 000000000000000000000000000011111111111000000000 count 0 1 2 3 4 5 6 Someone can help me? Thanks2 Replies
Another method would be to use two counters for each clock domain. Then design a module to re sync the counter values to the same clock domain before adding them together to get the total count.
Typically it's not possible to use two clocks on a register.
You should solve it like this: always(clk) begin if (bu==0) begin count <= count + 1'd1; end else begin count <= count + 5'd20; end end
