15 years agoProblem with uart and ethernet communication
I have same problem with uart communication.
I want receive data from ethernet and send to UART and vice versa. UART to Ethernet is OK, but Ethernet to UART is not OK. # define NETWORK_PORT 5000# define BUFFER_SIZE 32 # define true 1# define false 0 static char data_buffer[BUFFER_SIZE]; void DieWithError(const char *msg) { perror(msg); exit(1); } int open_socket(void) { int listen_fd; int incoming_fd; struct sockaddr_in my_addr; struct sockaddr_in other_addr; //socklen_t other_addr_len; int other_addr_len; int yes = 1; // create socket. listen_fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP); if(listen_fd == -1) DieWithError("socket"); if(setsockopt(listen_fd, SOL_SOCKET, SO_REUSEADDR, &yes, sizeof(int)) == -1) { DieWithError("setsockopt SO_REUSEADDR"); } if(setsockopt(listen_fd, SOL_SOCKET, SO_KEEPALIVE, &yes, sizeof(int)) == -1) { DieWithError("setsockopt SO_KEEPALIVE"); } my_addr.sin_family = AF_INET; my_addr.sin_port = htons(NETWORK_PORT); my_addr.sin_addr.s_addr = INADDR_ANY; memset(my_addr.sin_zero, '\0', sizeof(my_addr.sin_zero)); if(bind(listen_fd, (struct sockaddr *)&my_addr, sizeof(my_addr)) == -1) DieWithError("bind socket"); printf("Listening on %s, port %d.\n", inet_ntoa(my_addr.sin_addr), ntohs(my_addr.sin_port)); // listen if(listen(listen_fd, 1) == -1) DieWithError("listen socket"); // accept connection. other_addr_len = sizeof(struct sockaddr_in); if((incoming_fd = accept(listen_fd, (struct sockaddr *)&other_addr, &other_addr_len)) == -1) DieWithError("accept socket"); // close socket. if(close(listen_fd) == -1) DieWithError("close old socket"); printf("New connection from %s, port %d.\n", inet_ntoa(other_addr.sin_addr), ntohs(other_addr.sin_port)); return incoming_fd; } // close socket void close_socket(int fd) { if(close(fd) == -1) DieWithError("close socket"); } // open uart. int open_serialport(void) { int fd; // open uart. fd = open("/dev/uart", O_RDWR | O_NOCTTY | O_SYNC); if(fd == -1) DieWithError("open serialport"); return fd; } // close serialport void close_serialport(int fd) { if(close(fd) == -1) DieWithError("close serialport"); } int fromuartTask(void) { int network_fd; int serial_fd; fd_set read_fds; struct timeval tv; int tmp; // open uart and network connection serial_fd = open_serialport(); network_fd = open_socket(); while(1) { FD_ZERO(&read_fds); FD_SET(network_fd, &read_fds); FD_SET(serial_fd, &read_fds); tv.tv_sec = 0; tv.tv_usec = 0; // wait. if(network_fd > serial_fd) tmp = network_fd; else tmp = serial_fd; if(select(tmp + 1, &read_fds, NULL, NULL, &tv) == -1) DieWithError("select"); // Ethernet data ?? if(FD_ISSET(network_fd, &read_fds)) { // recv from ethernet. printf("wait for network data.\n"); tmp = recv(network_fd, data_buffer, BUFFER_SIZE, 0); if(tmp == -1) DieWithError("recv"); if(tmp == 0) break; // write to uart. if(write(serial_fd, data_buffer, tmp) == -1) DieWithError("write"); printf("Got network data.\n"); } // Data from UART?? if(FD_ISSET(serial_fd, &read_fds)) { // read from uart. printf("waiting for serial data.\n"); tmp = read(serial_fd, data_buffer, BUFFER_SIZE); if(tmp == -1) DieWithError("read"); // send to ethernet. if(send(network_fd, data_buffer, tmp, 0) == -1) DieWithError("send"); printf("Got serial data.\n"); } } // close socket and serial port close_socket(network_fd); close_serialport(serial_fd); return 0; }1 Reply
It was a long time age that I tried, but IIRC the select() call doesn't work well with the Interniche stack. It only detects incoming data on one of the sockets, but not both.
This was a long time ago (with Quartus 7.2 I think) so it may have been fixed since then. Otherwise you could try to use two threads to read data on each socket.
