Problem with PLL in EP1C12 device
Hello everyone, long time no see =]
Recently I've built my own evaluation board with EP1C12 Cyclone device (yes, it's an old one, but I obtained it for free). The board is working, I can configure the FPGA using JTAG Byte Blaster (parallel port), also FPGA chip is working properly, except the PLL. I've created simple test project, which uses PLL. The PLL is created as a Altera Megafunction and it's suppose to double the clock frequency (from 50 MHz to 100 MHz). Reset and clock signals are connected properly to PLL core. What could be wrong ? The code is listed below. PLL_test.vhd:library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_ARITH.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
entity PLL_test is
generic
DIV_FACTOR : positive := 20
port
clk : in std_logic;
nrst : in std_logic;
divout : out std_logic;
locked : out std_logic
end PLL_test;
architecture behavioral of PLL_test is
COMPONENT PLL IS
PORT
areset : IN STD_LOGIC := '0';
inclk0 : IN STD_LOGIC := '0';
c0 : OUT STD_LOGIC ;
locked : OUT STD_LOGIC
END COMPONENT;
signal divider : std_logic_vector(15 downto 0);
signal div_rst,div_clk,PLL_lock : std_logic;
begin
clk_mul : PLL
PORT MAP
areset => not nrst,
inclk0 => clk,
c0 => div_clk,
locked => PLL_lock
div_rst <= PLL_lock and nrst;
locked <= PLL_lock;
freq_divider : process(div_clk,div_rst) is
begin
if div_rst = '0' then
divider <= (others => '0');
divout <= '0';
elsif rising_edge(div_clk) then
divider <= divider + 1;
if divider <= DIV_FACTOR/2 then
divout <= '0';
else
divout <= '1';
end if;
if divider = DIV_FACTOR then
end if;
end if;
end process freq_divider;
end behavioral; The divider is supposed to generate signal with frequency ten times lower than PLL clock out frequency (10 MHz in this case), cause my oscilloscope is old and has bandwidth of 25 MHz.15 Replies
It was missing PLL power supply. I will check later if PLL works correctly.
Ok, I'll check those.
In my opinion, possible causes are:
- Wrong clock frequency - Incorrect PLL configuration - Missing or unstable or out-of-range PLL power supply - Altera_Forum
I tried Your solution, but it still doesn't work. I even tried to use other PLL. No luck there either. Any ideas ?
I don't see anything wrong with your code.
I know once a stratix PLL didn't lock because of long reset. Try these: remove reset signal check the lock signal directly. - Altera_Forum
I used this clock directly and FPGA works properly, the output is toggling.
You better probe it and measure or use it inside fpga bypassing PLL and see it is toggling at least.
OK, but as a clock source is quartz generator, like this (but 50 MHz): http://www.tme.eu/generator-kwarcowy-obudowa-metalowa-50mhz-33v/arts/pl/a09/qo1_00.html , so it's almost impossible that the input frequency is different.
Make sure your clk is indeed 50Mhz to fpga
I've checked pin connections several times. I've checked if any of used pins isn't broken. Everything is OK, except the PLL won't start. The lock signal is constantly low.
