Anonymous
4 years agoNot applicable
Problem with IRQ bridge in Platform Designer and Nios II SBT for Eclipse
I have a simple platform designer system containing a NIOS, a custom component, an Avalon-MM bridge and an IRQ bridge. When I generate the HDL files for this system everything works without e...
AlexW1
3 years agoIn an old Qsys manual, I found a note:
Nios II BSP tools do not fully support the IRQ Bridge. Interrupts connected via an IRQ Bridge will not appear in the generated system.h file
I think if you really want to use that module, you'll have to make some #defines yourself. As an alternative, you can use a PIO module with an interrupt as a workaround.
