14 years ago
Problem with IP Compiler for PCIe
Hello everyone!
I am new to HDL and have a problem with my work. I have Cyclone IV GX transceiver starter kit and wanted to test "SOPC Builder Design Example" from "IP Compiler for PCI Express User Guide".
I only changed PCI Express lanes to x1 and disabled "Test out witdh".
After finishing generating the SOPC bilder system I want to compile the design, but when the compilation starts the fitter a problem occurs:
Error (176205): Can't place 89 pins with 2.5 V I/O standard because Fitter has only 62 such free pins available for general purpose I/O placement
Error (176204): Can't place pins due to device constraints
Error (171000): Can't fit design in device
Error: Quartus II 32-bit Fitter was unsuccessful. 3 errors, 36 warnings
Now my question, when I look in the Pin Planer there are 40(!) test_in_pcie_compiler_0 pins. I guess they are the problem, but how do I delete them or even not initialize those pins?
ps.: FPGA: EP4CGX15BF14C8
Thanks for answers!
Best regards
RK
    i'm not sure if you can turn them off
    for now, you could assign 1 input bit to the whole bus. that should keep it from optimizing anything out
    So is there any option to avoid the creation of test_in pins? Because there is one to turn off the test_out pins.
    Or can I just delete/comment out the initialization of the pins?
    i think Virtual Pins are only supported in Subscription Edition, so in Web Edition they may be ignored
    Then You're doing something wrong. Are You sure You've set the CORRECT pins as virtual pins?
    Even when I add the test pins to the assignment editor and set them virtual the same message occurs. Same when I set "Enabled" to "NO". :(
