11 years agoProblem with Data Integrity & Clock between 2 FPGAs
Hi I have a problem with data integriry & clock between 2 FPGAs. A scheme of my design is inserted at the end. My design consists of 2 Cyclone III FPGAs. Each FPGA has several clock domains, eac...
11 years ago --- Quote Start --- I hoped that half of clock cycle is sufficient for all delays --- Quote End --- Why hope when you can "design"? Did you create a TimeQuest .SDC file? If not, its time to learn. The synthesis tool will make no attempt to meet external timing if you do not provide it the information it needs to understand what the external timing requirements are. Cheers, Dave
