18 years agoProblem of download the code in altera cyclone II kit.
Hello, i am using Altera cyclone II EP2C35F672C6N kit. i have problem of downloading the code in that kit. Error led of board turned on when i was trying to download the code in to the kit, b...
17 years ago --- Quote Start --- Have you ever used tcl scripts?? I have the problem sometimes, and what I do is, I add all the standard pin assignments into my tcl script, and run it. So now, (after compilation) when you open the pin planner, every possible pin has an assignment. The you just change the pins that you are going to be using in the pin planner, and compile it again, and then the problem should hopefully go away. I've attached the standard pin assignments as a *.txt file. If you need a step-by-step for the tcl script then let me know... --- Quote End --- I would be actually really interested in knowing how to do it, I have never used TCL Scripts and I think it would extremely help me in my current design. Thanks in advance!
