15 years agoProblem in running NIOS II Software Project on Altera
I keep getting this error while trying to run software projects built in NIOS II IDE using cable "usb-blaster [usb-0]", device 1, instance 0x00 pausing target processor: not responding. res...
15 years agoHi sudattuladhar,
A few question that can help to understand where the problem is: - Are you sure your fpga design meets timing requirements? - What's the Nios clock frequency you are using? - Are you loading the program into onchip ram or in a sdram? - if your code is loaded in sdram,, are you sure it is working correctly and timing is correct? Regards
