11 years agoproblem in interfacing
Hi all,
can any one suggest me how to interface altera cyclone 3 fpga starter kit( EP3C25F324 ) and ti daughter card ( SDALTEVK/NOPB ). i have both boards. when i see both schematic diagram then find some of pins iof HSMC not matched together ( like:- HSYNC , ODDEVEN, VFORMAT etc.). so plz suggest how to interface together. it is possible to interface both devices ?? if no then which device configure to SDALTEVK/NOPB.19 Replies
HELLO SIR, NO ACTION IS DONE WHEN I APPLY IO_MS_TOGGLE_RATE TO 0 MHz. SO ANY OTHER SOLUTION PLZ PROVIDE ME.
i give you full detail of pin location, for your more understanding.
altera_reserved_tck Input 2.5 V (default) 8mA (default) altera_reserved_tdi Input 2.5 V (default) 8mA (default) altera_reserved_tdo Output 2.5 V (default) 8mA (default) 2 (default) altera_reserved_tms Input 2.5 V (default) 8mA (default) clkin_50 Input PIN_A9 8 B8_N0 1.8 V 8mA (default) CLKOUT_SMA Output PIN_A1 8 B8_N0 1.8 V 8mA (default) 2 (default) DIPSW[7] Input PIN_H15 6 B6_N0 2.5 V 8mA (default) DIPSW[6] Input PIN_D17 6 B6_N0 2.5 V 8mA (default) DIPSW[5] Input PIN_H13 6 B6_N0 2.5 V 8mA (default) DIPSW[4] Input PIN_D18 6 B6_N0 2.5 V 8mA (default) DIPSW[3] Input PIN_C17 6 B6_N0 2.5 V 8mA (default) DIPSW[2] Input PIN_M5 2 B2_N0 2.5 V 8mA (default) DIPSW[1] Input PIN_P18 5 B5_N0 2.5 V 8mA (default) DIPSW[0] Input PIN_R16 5 B5_N0 2.5 V 8mA (default) freerun Output PIN_T17 5 B5_N0 2.5 V (default) 8mA (default) 2 (default) genlock_no_lock Input PIN_M6 3 B3_N0 2.5 V 8mA (default) genlock_no_ref Input PIN_M13 4 B4_N0 1.8 V 8mA (default) hsync_n Input PIN_E1 1 B1_N0 1.8 V 8mA (default) 0 MHz hsync_p Input PIN_E2 1 B1_N0 2.5 V 8mA (default) 0 MHz I2C_SCL Bidir PIN_N16 5 B5_N0 2.5 V (default) 8mA (default) 2 (default) LED[7] Output PIN_E9 8 B8_N0 1.8 V 8mA (default) 2 (default) LED[6] Output PIN_C9 8 B8_N0 1.8 V 8mA (default) 2 (default) LED[5] Output PIN_E10 8 B8_N0 1.8 V 8mA (default) 2 (default) LED[4] Output PIN_D9 8 B8_N0 1.8 V 8mA (default) 2 (default) LED[3] Output PIN_N9 3 B3_N0 1.8 V 8mA (default) 2 (default) LED[2] Output PIN_N12 4 B4_N0 1.8 V 8mA (default) 2 (default) LED[1] Output PIN_P12 4 B4_N0 1.8 V 8mA (default) 2 (default) LED[0] Output PIN_P13 4 B4_N0 1.8 V 8mA (default) 2 (default) oddeven_n Input PIN_L18 5 B5_N0 2.5 V (default) 8mA (default) oddeven_p Input PIN_K18 5 B5_N0 2.5 V (default) 8mA (default) PBSW[3] Input PIN_B10 7 B7_N0 1.8 V 8mA (default) PBSW[2] Input PIN_A10 7 B7_N0 1.8 V 8mA (default) PBSW[1] Input PIN_F2 1 B1_N0 2.5 V 8mA (default) PBSW[0] Input PIN_F1 1 B1_N0 2.5 V 8mA (default) pll_clk_n Input PIN_F18 6 B6_N0 2.5 V (default) 8mA (default) pll_clk_p Input PIN_F17 6 B6_N0 2.5 V (default) 8mA (default) PLL_SDA Bidir PIN_N11 4 B4_N0 1.8 V 8mA (default) 2 (default) rst_n Input PIN_R17 5 B5_N0 2.5 V (default) 8mA (default) RX1_SDA Bidir PIN_N15 5 B5_N0 2.5 V (default) 8mA (default) 2 (default) rx_clk_n Input PIN_N18 5 B5_N0 2.5 V (default) 8mA (default) rx_clk_p Input PIN_N17 5 B5_N0 2.5 V (default) 8mA (default) rx_d_n[4] Input PIN_P1 2 B2_N0 2.5 V (default) 8mA (default) rx_d_n[3] Input PIN_L3 2 B2_N0 2.5 V (default) 8mA (default) rx_d_n[2] Input PIN_L5 2 B2_N0 2.5 V (default) 8mA (default) rx_d_n[1] Input PIN_H1 1 B1_N0 2.5 V (default) 8mA (default) rx_d_n[0] Input PIN_C1 1 B1_N0 2.5 V (default) 8mA (default) rx_d_p[4] Input PIN_P2 2 B2_N0 2.5 V (default) 8mA (default) rx_d_p[3] Input PIN_L4 2 B2_N0 2.5 V (default) 8mA (default) rx_d_p[2] Input PIN_K5 2 B2_N0 2.5 V (default) 8mA (default) rx_d_p[1] Input PIN_H2 1 B1_N0 2.5 V (default) 8mA (default) rx_d_p[0] Input PIN_C2 1 B1_N0 2.5 V (default) 8mA (default) sdi_ck_en1 Output PIN_J13 6 B6_N0 2.5 V (default) 8mA (default) 2 (default) 0 MHz sdi_ck_sel0 Output PIN_H16 6 B6_N0 2.5 V (default) 8mA (default) 2 (default) 0 MHz sdi_ck_sel1 Output PIN_N10 4 B4_N0 1.8 V 8mA (default) 2 (default) 0 MHz tof_n Input PIN_M17 5 B5_N0 2.5 V (default) 8mA (default) tof_p Input PIN_L16 5 B5_N0 2.5 V (default) 8mA (default) TX1_SDA Bidir PIN_E17 6 B6_N0 2.5 V (default) 8mA (default) 2 (default) TX2_SDA Bidir PIN_H17 6 B6_N0 2.5 V (default) 8mA (default) 2 (default) 0 MHz tx_clk_n Output PIN_D1 1 B1_N0 2.5 V (default) 8mA (default) 2 (default) tx_clk_p Output PIN_D2 1 B1_N0 2.5 V (default) 8mA (default) 2 (default) tx_d_n[4] Output PIN_M1 2 B2_N0 2.5 V (default) 8mA (default) 2 (default) tx_d_n[3] Output PIN_L1 2 B2_N0 2.5 V (default) 8mA (default) 2 (default) tx_d_n[2] Output PIN_K1 2 B2_N0 2.5 V (default) 8mA (default) 2 (default) tx_d_n[1] Output PIN_G1 1 B1_N0 2.5 V (default) 8mA (default) 2 (default) tx_d_n[0] Output PIN_B1 1 B1_N0 2.5 V (default) 8mA (default) 2 (default) tx_d_p[4] Output PIN_M2 2 B2_N0 2.5 V (default) 8mA (default) 2 (default) tx_d_p[3] Output PIN_L2 2 B2_N0 2.5 V (default) 8mA (default) 2 (default) tx_d_p[2] Output PIN_K2 2 B2_N0 2.5 V (default) 8mA (default) 2 (default) tx_d_p[1] Output PIN_G2 1 B1_N0 2.5 V (default) 8mA (default) 2 (default) tx_d_p[0] Output PIN_B2 1 B1_N0 2.5 V (default) 8mA (default) 2 (default) vformat_n Input PIN_R1 2 B2_N0 2.5 V (default) 8mA (default) vformat_p Input PIN_R2 2 B2_N0 2.5 V (default) 8mA (default) - Altera_Forum
Can you (are you happy to) post the .qsf file for the project? You'll find it in the same directory as the Quarus project (.qpf) file...
hello Sir,
plz tell me, what i do to resolve this error, and i know i did mistake but i dont know what i do. plz help me. - Altera_Forum
TO_BE_DONE
OK - I can basically make your Quartus Settings File (qsf) file work. However, can you confirm you're still using the Cyclone III Dev kit you mentioned in your first post?
If so, the qsf you sent is specifying the wrong device. That kit features a Cyclone III EP3C25F324. Your settings file calls up an EP3C120F780. You've also previously referred to "hsync_n" and it being placed at E1 or maybe G18. Your project settings are trying to put it on L1...? So, I think you have a little work to do. There a quite a few inconsistencies with all the info you've posted. Go over the project's settings thoroughly and make sure you're happy that you have the right device and pinout. Cheers, Alex - Altera_Forum
hello sir,
i am upload wrong .qsf file, in this post you can find the correct .qsf file in the Zip folder. i m sorry for this. - Altera_Forum
Are you still having problems with this?
A quick look at the .qsf you posted shows a conflict between the 'hsync_p' & 'hsync_n' signals. One is 1.8V, the other 2.5V. I think you should be generating hsync as a differential signal. However, your qsf shows different single ended I/O standards for each half of the pair. If you still need help let me know. Happy New Year, Alex
