11 years agoproblem in interfacing
Hi all, can any one suggest me how to interface altera cyclone 3 fpga starter kit( EP3C25F324 ) and ti daughter card ( SDALTEVK/NOPB ). i have both boards. when i see both schematic diagram the...
11 years agoOK - I can basically make your Quartus Settings File (qsf) file work. However, can you confirm you're still using the Cyclone III Dev kit you mentioned in your first post?
If so, the qsf you sent is specifying the wrong device. That kit features a Cyclone III EP3C25F324. Your settings file calls up an EP3C120F780. You've also previously referred to "hsync_n" and it being placed at E1 or maybe G18. Your project settings are trying to put it on L1...? So, I think you have a little work to do. There a quite a few inconsistencies with all the info you've posted. Go over the project's settings thoroughly and make sure you're happy that you have the right device and pinout. Cheers, Alex
