18 years ago
problem changing static IP in socket server application
I'm trying to test simple sockect server example in Cyclone III NIOS II eval kit using NIOS IDE 8.0.
I checked this example in my old version 7.2 of Quartus and it worked fine!!!
I tried to change static IP in simple_socket_server.h using
# define IPADDR0 192
# define IPADDR1 168
# define IPADDR2 10
# define IPADDR3 11
and settind *use_dhcp=0
by making those changes my simple socket server application worked in 7.2. but in this 8.0 version the static IP never changes from the adress 0.10.10.11.
I've debugged the code and I think htonl instruction doesn't work properly.
# define IP4_ADDR(ipaddr, a,b,c,d) ipaddr =
htonl(((alt_u32)(a & 0xff) << 24) | ((alt_u32)(b & 0xff) << 16) |
((alt_u32)(c & 0xff) << 8) | (alt_u32)(d & 0xff))
any suggestion??
    I've modified simple socket server to be UDP instead TCP server.
    I've tried to set the destination IP addres by using
    UDP_sender.sin_family = AF_INET;
    UDP_sender.sin_port = htons(30);
    inet_atom ("192.168.10.10", UDP_sender.sin_addr);
    or using
    IP4_ADDR (UDP_sender.sin_addr.s_addr,192,168,10,10);
    both possibilities were working in EDS 7.2 but doesn't in EDS 8.0
    When running both attempts, compiler is failing because 'IP4_ADDR' or 'inet_atom' are undefined references.
    then following your comments the difference between my 7.2 and 8.0 could be the NIOS endian configuration
    This function , simply reorders the bytes according to the processor endianess.
    The only reason I see for which it didtn't work is due to your processor endianess.
    The project now works as in EDS 7.2. Thank you for giving me this solution.
    Could you explain to me why I didn't have to use this instruction in EDS 7.2???
    Do you know another difference in EDS 8.0 ??
    What about with the endianess?
    try whit this code:
    unsigned int htonl (unsigned int x) {
    # if BYTE_ORDER == LITTLE_ENDIAN
    unsigned char *s = (unsigned char *) &x;
    return (unsigned int) (s[0] << 24 | s[1] << 16 | s[2] << 8 | s[3]);
    # else return x;# endif }
