Preconfiguration BSDL Editor for Agilex 7 with disabled F-Tiles
Thank you for getting back to me, but please note that we're already using the tcl that your response references! The issue is that the tcl file that Altera is supplying doesn't modify the BSDL file correctly and doesn't generate a BSDL file with valid syntax!
Please can you raise this issue with Core Fabric Altera Support, because that's who the tcl file says to notify of any issues.
Hi Rob,
Thank you for your patience. I have confirmed that the same issue is being handled through Altera Premier Support (APS), where a revised BSDL with the 12B/13B sections removed has been supplied for validation. Its syntax and scan length still need checking against your board.
As this issue is already being investigated through the related APS case, I will close this forum thread to avoid duplicate tracking. This closure applies only to the forum discussion; the technical investigation continues through APS.
Fakhrul
