10 years agoPowering FPGA During Programming
Hi everyone- I am finalizing a PCB layout using a Max10 FPGA. This PCB will (hopefully) go into production in our small electronics business, and it will usually be programmed by technicians o...
10 years agoIf you supplied 3.3V to your board via the VCC pin of the JTAG header, would your board and FPGA power up correctly?
If it will, then yes - you could "intercept" VCC and supply 3.3V to both your board and the USB-Blaster. You could create an adapter board with a 2x5 way socket to plug onto your board and a 2x5 way header to take a USB-Blaster (all header/socket pins could be connected 1-1, 2-2 etc.). The adapter board would also have a connector through which you'd supply 3.3V. If your design relies on other rails, to either generate the 3.3V (and/or other) rail(s), then the solution is going to be more involved and will, almost certainly, amount to you making a board to 'host' and power your daughter board. When designing with FPGAs always consider - as early as possible - the practicalities of programming it and putting the thing to use, both in the lab and in production. Cheers, Alex
