Power supply requirements for Cyclone III
I'm looking for information on what the power supply requirements are for Cyclone III devices.
The starter kit evaluation board has 5 different regulators at 1.2V, 1.25V, 1.8V, 2.5V and 3.3V. I was hoping I could skip or consolidate some of these, obviously I need the 1.2V for the core and 3.3V or whatever for the I/O but I'm unsure about the rest. I intend to use only 3.3V I/O. I have a third party eval board for an older Cyclone EP1C6 and that makes do with only two regulators as far as I can tell.4 Replies
The FPGA uses different power supplies for different parts of the chip. The Cyclone III requires a 1.2V supply for its core and 2.5V for its plls, and you can use any supply voltage between 1.2 and 3.3V for the inputs/outputs.
I am going to use FPGA for the first time.I have a very basic question here.What is core power?Can I give 3.3 V as input signal to Cyclone III FPGA's even though power supply requirement is 1.2V,1.8V etc.
Ok. I'm also wondering, the FPGA in the EQFP144 case has about 32 supply pins. Is there any guide to what kind of bypass caps I should use with this chip and how many of them? I counted 29 caps on the bottom of the starter kit, underneath the chip but that's a BGA chip with a lot more supply pads than the 32 I have. I'm sure there's a document somewhere about exactly this but I have no idea where to look for it.
1.2V core supply and 2.5V VCCA are required, others are optional, depending on your application. So if you intend to use 3.3V VCCIO, you need 3 regulators. The VCCA current requirement is low however, a tiny SOT23 regulator is typically sufficient. Even a silicon diode from 3.3V can do in some cases.
