Ian_Maw
10 months agoPower Rating Required for RZQ Resistor on Cyclone V SE
Hi, I need to include the 100R resistor we are using connected to RZQ pin D21 on the 484 ball package. Can anyone tell me what the maximum current I would realistically experience. If I just assume...
AqidAyman_Altera
10 months agoHi,
Through my knowledge, Altera does not publish a maximum current through the RZQ pin or a required resistor wattage. Based on the intended function, the current is small, and a standard low-wattage precision resistor is typically sufficient.
Thank you.
- Ian_Maw10 months ago
Thanks, but the problem is that I need to have a figure for my derating. I can't just make up a number, with respect. I do think that Altera should be able to provide this information.
