19 years agoPower on Reset & state machines
Hi, I am using MAX II cplds & have a couple of questions. Can anyone explain to me what state a state machine goes into after Power-Up? if My State_type definition is this: type STATE_TYPE is (A,B...
19 years ago --- Quote Start --- I tried "pre-setting" this port, in vhdl: foo: std_logic := '1', & it still didnt fix it. shouldnt it have? --- Quote End --- All internal registers (registers not in I/O cells) power up low and cannot be made to power up high. Synthesis might make a register appear to initialize high by inverting the register input and output. I don't know whether synthesis should do that in your case. There are synthesis warnings (might be Info messages) about power-up don't care. They probably relate to this situation. See whether you have warnings about that.
