10 years agoPower on detection
Hello, please help me solving the issue. I have FPGA (cyclone-3 based) module connected to another system. That system generates reset signal on power on, and FPGA translates this signal to its...
10 years ago --- Quote Start --- And after x ammount of time changing that value. --- Quote End --- It would be ideal solution if one possible condition. Imagine, as proposed in that thread, I set up initial counter to be 0, and clock is running asynchronously. If all bits of register setup, from X to 0, will happen on the rising edge of the clock of counter (reg[..]<=reg[...]+1) it is big question which value reg[...] will get. I assume all bits in reg[...] are affected by it, not just bit 0 as assumed here http://www.alteraforum.com/forum/showthread.php?t=6602&page=3&p=27012#post27012.
