10 years agoPower on detection
Hello, please help me solving the issue. I have FPGA (cyclone-3 based) module connected to another system. That system generates reset signal on power on, and FPGA translates this signal to its...
10 years agoWell to the first:
--- Quote Start --- well, not sure if this is what you are after, nut you could bring an output pin on the fpga active for an x ammount of time and then deactivate it and use that for the device reset. --- Quote End --- --- Quote Start --- @PietervanderStar: hardware design was already done, --- Quote End --- This is along the lines I was thinking. --- Quote Start --- setting initial values of the register. --- Quote End --- And after x ammount of time changing that value. For the second, you could read this (http://www.alteraforum.com/forum/showthread.php?t=45135&highlight=reset+synchroniser) thread.
