Power and thermal characterization of Agilex 5
We are working on the power characterization of a design based on the Agilex5 E-series and I've come across a few questions I haven't been able to fully resolve from Altera's documentation. Would you be able to help?
1) Typical static power model:
I'd like to evaluate a typical static power consumption, but the latest Quartus tool (26.1.0, build 110) only provides max characteristics.
Q1: When does Altera plan to release the typical model?
Q2: In the meantime, would it be possible to get access to a pre-release model or estimates of how leakage power differs between the typical and max process corners?
2) Power and thermal analyzer breakdown for an empty design:
For an almost empty design (only a single FF driven by an external clock), the report shows several power components I'd like to understand better:
- a) the design uses no DSP or RAM blocks but both static and dynamic power are reported for them.
Q3: Which fabric components draw power even when unused?
- b) The I/O contributes significantly.
Q4: Is this only the clock buffer and the SDM/Active Serial config-related buffers that Quartus inserts automatically or are there additional assumptions behind it?
- c) The "Miscellaneous" also contributes significantly to the total power consumption.
Q5: Could you clarify what this category includes?
3) Powering down unused blocks:
Q6: Can the HPS and transceivers be fully powered down, i.e., voltage rails disconnected to save power?
For reference, I'm on Ubuntu 26.04 with Quartus 26.1.0 (build 110). I've attached the Quartus project for the "empty" design with its power analysis report.
I appreciate your help and I look forward to hearing from you.
Chris
- glenenglish
Hi Chris
Not sure if you are still subscribing to this topic, but you are not the only one looking at the high static power of this family.. We have got a solution/workaround (for our use cases) . We have heavily evaluated A5E for migrating current designs and new designs (we're a experienced Xilinx house).Indeed I found the results from the Power and Thermal Analyser confusing and bewildering.
I also find totally terrible from an usage / intuition POV , can't figure out what is on, off and cant tweak core volts (can this be done) for a specific device. Altera should go look at any Xilinx power analysis tool.anyway....High static power appears to be a thing with this process node. I think we have a workaround / method to deal with it - In the lower speed tiers 4,5,6 , you might use the -6X speed grade. This binned grade, the static power is down significantly on the -6S
There are things we considered in this configuration :
While -6X runs at 0.75V, If we need more speed, we will simply up the core voltage, as the VCCCORE regulator we use has a I2C control input (TPS6287B10L (there is a whole family of these with variations )) . This is probably not Altera recommendation, but my experience tells me it will be OK and work fine as long as thermals are kept in check. There will of course be limits to this.
Even though the DSP blocks are slower for 18x19 in this mode than 7 series 28nm xilinx, they of course can do alot more than the old DSP48 tech in functionality.regards, glen .
- Farabi_Altera
Hello Chris,
1- Typical static power model
i- When the typical static power model will be available?
Ans: Please refer here Table 23
ii- access to pre-release model
Ans: All the E-series power model is updated in 26.1
2- Power and Thermal Analyzer on empty design
i(a)- design use no DSP or RAM blocks
Ans: This is expected. Even no DSP or M20K blocks instantiated, the silicon physically contributes leakage/static power.
i(b)- Which fabric component draw power significantly
Ans: clock input buffer, Global clock, configuration related circuitry, SDM, default termination, unused IO bank static leakage etc.IO is only one part of the contributors.
i(c) - what is included in miscellaneous category?
Ans: SDM related circuit, Configuration circuit, Device management logic, power-monitoring circuit(POR), temperature/voltage sensing circuit, etc.
3- Can HPS and transceivers by fully powered down by disconnecting the power rails?
Ans: Basically yes, but why? you can choose device variance without HPS and without transceiver if you dont want this feature. This variance comes without HPS and transceivers.
regards,
Farabi- KJ
Hi Farabi,
Thank you for your answers. They are very useful.
With regards to power consumption of uninstantiated DSP and M20K blocks, the report shows they also contribute to dynamic power consumption, as opposed to just leakage power. Could you clarify why?
With regards to powering down HPS/transceivers, choosing the part that doesn't have those in the first place would be ideal, but not all fabric sizes for Agilex 5 E come with that configuration option, unfortunately.
Chris
- Farabi_Altera
Hello Chris,
Do you have further question?
rgards,
Farabi
