Alex02
4 years agoPossible Compatibility Issue Between Intel Cyclone 10 GX Dev Kit and Xilinx FMC-105-Debug
I am working with the Cyclone 10 GX Dev Kit and have successfully run programs on it before.
I am trying to use the Xilinx FMC to debug signals from the FPGA and eventually communicate with another...
ak6dn
4 years agoWhat makes you think the AMD/Xilinx FMC105 card is in any way pinout compatible with the Intel/Altera Cyclone 10 GX board?
They may both use the same FMC type connector, but have you compared physical pin assignments?
Neither boards documentation lists the other as being compatible.
