15 years agoPort map verilog module in vhdl
How can I port map a verilog module/file in an VHDL top module? I've tried the normal VHDL way without any luck. Thanks for any help.
i don't think you'll be able to use VHDL direct instantiation of a Verilog module, so you will need to include the component declaration as described above
What do you mean for the normal VHDL way?
In Quartus there is no problem: you can use the functions in the File menu to create the VHDL component declaration template of a Verilog module (and vice versa). If you mean to mix VHDL and Verilog in ModelSim, this is not allowed in Altera Starter Edition, if I remember correctly.
