15 years agoPort map verilog module in vhdl
How can I port map a verilog module/file in an VHDL top module? I've tried the normal VHDL way without any luck. Thanks for any help.
15 years agoWhat do you mean for the normal VHDL way?
In Quartus there is no problem: you can use the functions in the File menu to create the VHDL component declaration template of a Verilog module (and vice versa). If you mean to mix VHDL and Verilog in ModelSim, this is not allowed in Altera Starter Edition, if I remember correctly.
