POPs & PFOAs declarations
Could you please provide POPs & PFOAs declarations for the following products: -
| 10AX066K4F35E3SGAA |
| 10AX066K4F35E3SG |
| 10AX090N4F40E3SGJZ |
| 10CL120YF780C8G |
| EP2AGX45DF25C6G |
| EP2C20F256C8N |
| EP2C5T144C8N |
| EP2C8F256C8N |
| EP3C120F780C8N |
| EP3C16F256C8N |
| EP3C16F484C8N |
| EP3C25F324C8N |
| EP3C40F780C8N |
| EP3C55F484C8N |
| EP3C55F780C8N |
| EP3C5F256C8N |
| EP3C80F780C8N |
| EP4CE115F23xxx |
| EP4CE15F17C8N |
| EP4CE40F23C8N |
| EP4CE55F23C8N |
| EP4CGX110CF23C8N |
| EP4CGX150DF27C8N |
| EP4CGX50CF23C8N |
| EP4CGX75CF23C8N |
I have tried various things including the MMDs but have had no luck.
HI,
Sorry for the delay. Yes these documents can confirm that there are no POP or PFOAs substances present in each device.
Nazrul Naim
- VinceG
Thank you Nazrul.
- NazrulNaim_Intel
HI,
Nazrul Naim
- VinceG
See question above.
I have now downloaded all your MMDs for each part and converted them into a readable format.
Are you telling me that these documents can confirm that there are no POP or PFOAs substances present in each device?
Is that correct?
Vince
- NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, for now I will set this case to Close-Pending.
Nazrul Naim
- NazrulNaim_Intel
It seems like an issue for the SML File. Below is the step how to open XML file in Excel
- Open a new blank Excel file
- Click on Developer tab, then click Import
- Select the xml file you want to import, then click Import
- Click "OK" on pop-op information, and also "OK" on where to Import data
- The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
- I recommend to delete column AK so that the other columns will display better:
Hope that helps you resolve the issue.
Nazrul Naim
- VinceG
Is that correct?
Vince
- VinceG
Hi Nazrul,
As I mentioned earlier, that link takes me to the page, I put in the P/Ns I am interested in, but when I try to download the MMS, all I get is junk.
See below.
What am I doing wrong?
Vince
- NazrulNaim_Intel
After discussion with the internal team. For products that have been mentioned, we can refer you to Intel MDDS page https://www.intel.com/content/www/us/en/collections/content-type/mdds.html.
You can download a copy of individual MDDS for each part number to know if there is POPs or PFOAs substances.
Hope that answers your question.
Nazrul Naim
- NazrulNaim_Intel
Hi Vince,
Really sorry for the delay. I'm currently waiting for the internal team to provide the document regarding this. Really sorry for the inconvenience and thank you for your patience.
Nazrul Naim
- VinceG
Hi Nazrul,
any progress on this at all?
Vince
- NazrulNaim_Intel
Hello Vince,
Sorry for the delay. For more information regarding this, you can access through the link below.
Link : https://www.intel.com/content/www/us/en/support/programmable/articles/000080881.html
Nazrul Naim
- VinceG
Hi Nazrul Naim,
Sorry mate, that's no help at all.
I found that early on in my search, but I couldn't find any usable Material Declaration Sheet.
Do you have access to these for the product listed earlier?
If so, could you send me PDFS?
Vince
