VinceG
3 years agoPOPs & PFOAs declarations
Could you please provide POPs & PFOAs declarations for the following products: - 10AX066K4F35E3SGAA 10AX066K4F35E3SG 10AX090N4F40E3SGJZ 10CL120YF780C8G EP2AGX45DF25C6G EP2C20F256C8...
- 3 years ago
HI,
Sorry for the delay. Yes these documents can confirm that there are no POP or PFOAs substances present in each device.
Nazrul Naim
NazrulNaim_Intel
3 years agoHello,
It seems like an issue for the SML File. Below is the step how to open XML file in Excel
- Open a new blank Excel file
- Click on Developer tab, then click Import
- Select the xml file you want to import, then click Import
- Click "OK" on pop-op information, and also "OK" on where to Import data
- The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
- I recommend to delete column AK so that the other columns will display better:
Hope that helps you resolve the issue.
Nazrul Naim
VinceG
3 years agoHi,
I have now downloaded all your MMDs for each part and converted them into a readable format.
Are you telling me that these documents can confirm that there are no POP or PFOAs substances present in each device?
Is that correct?
Vince
