17 years agoPLL reconfiguration with NIOS
Hi
I'm working with a cyclone III FPGA with a NIOS. That NIOS is going to reconfigure a PLL via its Avalon bus. My question is: Can the NIOS reconfigure a PLL generating the NIOS clock, and doing that without any problem during the frequency changing ? Thank you for your answer !3 Replies
Thank you, I'm convinced.
I am going to make the NIOS working on another fixed clock. - Altera_Forum
Sounds like cutting the branch you are standing on. Another similar scenario is updating remotely your only one or two firmware images at the customer premises by a new image that didn't work, there would be no way back.
Boy that sounds dangerous. Honestly I wouldn't even attempt it. Is there some reason you need to reconfigure the NIOS's clock? I would recommend running the NIOS off of a different clock that you are not going to modify.
Jake
