17 years agoPLL reconfiguration with NIOS
Hi I'm working with a cyclone III FPGA with a NIOS. That NIOS is going to reconfigure a PLL via its Avalon bus. My question is: Can the NIOS reconfigure a PLL generating the NIOS clock, and ...
17 years agoBoy that sounds dangerous. Honestly I wouldn't even attempt it. Is there some reason you need to reconfigure the NIOS's clock? I would recommend running the NIOS off of a different clock that you are not going to modify.
Jake
