17 years agoPLL problem after power on reset
Hi, I'm sending data from an arriagx using the lvds block to a stratix fpga, looped through the stratix and back out to the arriagx. There are four lvds blocks involved and each has it's own pl...
17 years agoHi Motah,
I had come across somewhat similar problem. I had a PLL in startix II that was used tol receive a clock from DAC then its output clock(rotated) used to clock data out of fpga to DAC. It caused power-up problems. The phase was unpredictable. I contacted altera but eventually removed the PLL reset altogether and it was fine. I must also tell you that I didn't depend on signaltap but on actual signal spectrum after DAC. I don't give too much weight to signaltap in these circumstances. kaz
