16 years agoPLL outputs to drive 50 ohm loads
I need two outputs from a single PLL of CYCLONE-III 3C16. Both the outputs are single-ended. One of outputs is 100MHz and the other is 120MHz-200MHz which will be dynamically configured through NIOS-...
16 years agoFor best DAC (or ADC) performance, you shouldn't use a clock from a FPGA PLL. The clock jitter introduces a considerable phase noise amount. This is particularly the case in communication (or similar measurement) applications, where a high frequency signal is generated by the DAC. A LVDS output high frequency crystal oscillator will give better performance for this application.
