PLL not working on 10M16DCU324 FPGA_Quartus toll
- 1 year ago
As mentioned by FvM, according to the Pin Connection Guideline, you must connect all the VCCD_PLL pins 1.2V power supply. So I think your understanding is correct: you have to connect all the VCCD_PLL pins to power supply to make sure the PLL works normally on 10M16DCU324.
By the way, it seems you were trying to migrate the 10M02 board to 10M16. By comparing the Pin-out of 10M02DCU324 and 10M16DCU324, you can see there are multiple different pins, including GND, VCC, VCCA, VCCD_PLL and some VCCIO. Please also check if these pins are correctly connected for 10M16 as well.
10M02DC: Pin Information for the MAX® 10 10M02DC Device - XLSX Format (Alt. Format PDF)
10M16DC: Pin Information for the MAX® 10 10M16DC Device - XLSX Format (Alt. Format PDF)
MAX 10 PCG: MAX® 10 FPGA Device Family Pin Connection Guidelines
Xiaoyan
Hello
Thanks for sharing IO pin details, i have verified it and all the GND, VCC, VCCA, VCCD_PLL and VCCIO pins for 10M16DCU324 are connected as per shared details. Actually i have migrated from 10M08DCU324 to 10M16DCU324 so here both the devices have similar pins for GND, VCC, VCCA, VCCIO, only difference is VCCD_PLL2 and VCCD_PLL3 are additional pins in 10M16DCU324.
