12 years agoPLL Megafunction actual clock frequency
Hi, I am using the Altera PLL Megafunction to generate 6 different clocks (100, 125, 200,50, 1MHz) with a reference clock of 100 MHz. I set all the frequencies correctly except for the 1 MHz c...
12 years agoIf you don't need special clock shift,
you can use divider on flip-flop, example (verilog) wire clk_200; // (200MHz fom pll) reg clk_100; reg clk_50; always @(posedge clk_200) begin clk_100 <= ~clk_100; end always @(posedge clk_100) begin clk_50 <= ~clk_50; end
