9 years agoPLL clock switchover with automatic derivation of PLL clocks is not working
Hi all, I'm using a Cyclone V and need to switch between two input clocks. The clocks have the same parameters. I adhered to the timequest cookbook which says the following: #create a 10...
9 years agoHow are you selecting the input clock to the PLL? That logic may be why derive_pll_clocks isn't working. Can you post the HDL code? Normally, clock inputs make direct connections to PLLs.
