14 years agoPlease explain the following
I have one line in my VHDL test bench file as follows CONV_STD_LOGIC_VECTOR(16#100#+I*2,16) in for Loop integer I.
Could anyone please explain how can I plot this in waveform, I know some basic like CONV_STD_LOGIC_VECTOR(16#200#,16) will convert that into HEX so I can drive 200 in waveform3 Replies
BUS_ADDR_I already is an address bus.
I still dont understand what you are trying to do. Are you trying to wait between loop iterations?for I in 0 to 15 loop BUS_ADDR_I <= CONV_STD_LOGIC_VECTOR(16#100#+I*2, 16); wait until rising_edge(clk) ; end loop; - Altera_Forum
I am having test bench vhdl using that I am doing simulation on quartus simulator tool to check the design and use the same kind of vector to test in real time. For that I need to give input address which is std logic vector.
At some point in test bench vhdl code I got like this for I in 0 to 15 loop BUS_ADDR_I <= CONV_STD_LOGIC_VECTOR(16#100#+I*2, 16); .... ..... end loop; I need to simulate this input address in waveform file How to decode this in to address bus? Ex: If it is like the following BUS_ADDR_I <= CONV_STD_LOGIC_VECTOR( 16#0210#, 16); I'll drive address bus as 0x210 - Altera_Forum
I dont really understand your question. COuld you post more code in context?
