16 years agopins cannot be connect in orcad capture cis
Well, i download the ep3c16f484 symbol and footprint from altera website,
when i use the symbol in orcad capture cis project, the B part(ep3c16f484 is divided into 4 parts to describe itself) pins cannot be connect while other three parts(A,C,D) works well. i have searched on the net, buf found nothing that could help me out. can anyone here give me some help? The attachment give a simple view of my problem. thanks a lot ahead.3 Replies
i am sorry for my carelessness.
when i zoomed in the schematic(upsetted and unintentionally), i found that B part pins are all have a tiny offset with the grid, so i think you are right, jake. (i am sorry for not getting your point at the very beginning) i reedit the B part pins, and now they can be connected normally. it is curious that the four parts of ep3c16f484 are not edited under the same unit. thanks a lot and best wishes. - Altera_Forum
thanks for your replying.
well, i use the B page type in orcad with the mil as unit. superislying, in all total four symbol parts of ep3c16f484, A,C,D three parts work well whose pins can be connected normally, just B part cannot be connected. I checked the issue you said in orcad, but i donot get it out. best wishes - Altera_Forum
Looks to me like you've purely got an Orcad problem. Specifically, I'd guess your grid size needs to be adjusted. The schematic symbols were obviously created with a different grid size than what you are currently using. They may have been using mil (SAE) and you may be using mm (metric).
Jake
