16 years agopin assignement in a partition
I'm using incremental compilation and have compiled a design before include its .qxp in my top entity. The problem is that it seems like quartus is assigning pins to my compiled design and they are conflicting with my top pinout. Here's my question : How can I ask Quartus not to assign pins to my compiled design? Thank you!7 Replies
if you're using 10.0 it might be easier to just add the assignments to the .qsf:
set_instance_assignment -to $pin_name -name VIRTUAL_PIN ON - Altera_Forum
Thank you for your answer, I've just found another way. I Assign pins in pin planer to "Edge Bottom", then they appear in assignment editor and i change them to Virtual pins.
In fact i didn't found any <<new>> field in assignment editor... But it seems to work, my subproject is compiling right now, I'll come back later to say if it worked ;) - Altera_Forum
--- Quote Start --- I saw that in the LogicLock design methodology, but when I open assignement editor this is empty... --- Quote End --- Hi, yes that is the default, because you don't have made any assignment to your subproject. You have to fill the cells by your self. Go into the field "<<new>>". Right mouse click and choose "Node finder". List all your pins which you would like to set as virtual. Select all pins ( they should be seen on the right side now) and click ok. All your pins should now be visible in the assignment editor. Noe go into the field assignment. Double click into the field , scroll down and choose "Virtual pin". Now go into the field "Value" and choose "on". Now the pin(s) are set to virtual. Kind regards GPK - Altera_Forum
--- Quote Start --- It seems to be the solution, but I can't find how to assign virtual pins :s can you help me? --- Quote End --- Hi, have a look to the assignment editor. You will find an assignment "Virtual pin". Kind regards GPK - Altera_Forum
try assigning Virtual Pins to the lower level .qxp design
