16 years agopin assignement in a partition
Hello, I'm using incremental compilation and have compiled a design before include its .qxp in my top entity. The problem is that it seems like quartus is assigning pins to my compiled des...
16 years ago --- Quote Start --- I saw that in the LogicLock design methodology, but when I open assignement editor this is empty... --- Quote End --- Hi, yes that is the default, because you don't have made any assignment to your subproject. You have to fill the cells by your self. Go into the field "<<new>>". Right mouse click and choose "Node finder". List all your pins which you would like to set as virtual. Select all pins ( they should be seen on the right side now) and click ok. All your pins should now be visible in the assignment editor. Noe go into the field assignment. Double click into the field , scroll down and choose "Virtual pin". Now go into the field "Value" and choose "on". Now the pin(s) are set to virtual. Kind regards GPK
