16 years agoPHY Layer FPGA
With all the applications for SERDES and 1000BASE products, I would think that there might be a device which I could program that will perform the 100BASE-TX and/or 100BASE-FX function that I am look...
16 years agoAltera transceivers will not perform hard clock-data recovery for data rates below I believe 640Mbps or something like that. You could perform oversampling or soft-CDR but you wouldn't be able to use the recovered clock to re-transmit. You could use an external clock cleaner (like maybe an Si5234)
http://www.silabs.com/products/clocksoscillators/clocks/pages/any-ratejitterattenuatingclockmultipliers.aspx to restore the true clock from your soft-CDR clock. You'd want to provide the clock cleaner with a lower-frequency divided-down version of the clock in order to keep the jitter within spec. This also means you'd have to perform some buffering. I think you could make it work and honestly I think it would be fun but you'd have to do some experimentation. Seems like a Cyclone IV GX would be a good fit for something like this. Jake
